I see. Each one of these would be a separate dashboard then. You could have the same webmap in them or different ones, and set up the widgets accordingly.
The screenshot shows our web version of the Ops Dashboard running in the browser. Since each dashboard has a different webID from AGOL (and thus a different web address), you could write an HTML file with a few buttons that would control the call to each of the webmaps as you switch them along the top.
The other way you might be able to do this with no coding is using an Esri StoryMaps template and loading the dashboards in that way. I used the Tabbed Layout one and some public maps:
http://arcg.is/1INkpLl
Hope this helps!
Chris
