outStatistics returns 'unable to complete operation' BUG!
902
09-21-2016 11:52 AM
CameronBlandy
I have created an Operations Dashboard to monitor when our contractor replaces streetlights bulbs with new LED technology. I created the queries and all is fine when I create a Gauge widget in the Windows Operations Dashboard App.
When I share the app I get a no data message in the Gauge widget.
On close investigation the query to get the data is failing (using outStatistics in the Query). On the server I get a "General database error occurred" which explains nothing. However, on further investigation I found the issue has occurred with other users and ESRI has been able to replicate the issue (BUG-000092566). Since this was first recorded back in Nov 2015 I am wondering is ESRI plans on fixing this issue. Basically we cannot use the Operations Dashboard until this issue is fixed.
Can somebody at ESRI provide an update?
Cameron
ChristopherOlsen
Occasional Contributor III
This looks to be an Oracle DB bug that was logged with our ArcGIS Server team.  Can you post in their forum?
Chris
