has anyone heard why esri does not just include/fully-support that ago assistant?
"The esri fix-it tool"
reference:
Is ArcGIS Assistant supported by Esri?#
No. ArcGIS Assistant is a community-driven project from Esri Professional Services. While all of the requests from Assistant use supported ArcGIS REST API operations, doing so could leave your content in a broken or reduced state, and Esri Technical Support will not be equipped to help you with that situation.
