Hi -
I'm sure someone on here has asked this and received an answer, but I can't find it.
I have a data expression being used within a table element of a dashboard. I'd ideally like the user be able to make a selection (polygon) in the dashboard's map and then have the table be filter spatially based on the selection in the map using layer actions.
This code works great with a category selector, but not with my configured layer actions (it returns no data). I suspect my geometry is not being included in the Push and final FeatureSet (starts at lines 108 to end). Any suggestions on how to correct this?
// custom memorize function to increase performance of featureset
function Memorize(fs) {
var temp_dict = {
fields: Schema(fs)['fields'],
geometryType: Schema(fs).geometryType,
features: []
for (var f in fs) {
var attrs = {}
for (var attr in f) {
attrs[attr] = Iif(TypeOf(f[attr]) == 'Date', Number(f[attr]), f[attr])
Push(
temp_dict['features'],
{attributes: attrs, geometry: Geometry(f)}
return FeatureSet(Text(temp_dict))
// variable to define the portal URL
var portal = Portal("https://mass-eoeea.maps.arcgis.com");
//Quabbin and Ware Encroachments
var qEncroach = FeatureSetByPortalItem(portal,"1234abc",0,['Date_Found', 'Type', 'Encroachment_Priority', 'Description'],true);
//Wachusett and Sudbury Encroachments
var wEncroach = FeatureSetByPortalItem(portal,"5678def",0,['Date_Found', 'Type', 'Encroachment_Priority', 'Description'],true);
// Create a FeatureSet with all encroachments from Quabbin, Ware and Wachusett
var int_dict = {
fields: [
{'name': 'type', 'type': 'esriFieldTypeString'},
{'name': 'edate', 'type': 'esriFieldTypeDate'},
{'name': 'priority', 'type': 'esriFieldTypeString'},
{'name': 'descript', 'type': 'esriFieldTypeString'}],
geometryType: 'esriGeometryPoint',
"spatialReference": {
"wkid": 102100,
"latestWkid": 3857
}, 'features':[],
// Fill intermediate FeatureSet with encroachment info
var i = 0;
for (var f in qEncroach) {
int_dict.features[i] = {
attributes: {
'type': f["Type"],
'edate': DateDiff(f["Date_Found"], Date(1970, 0, 1, 0, 0, 0), "milliseconds"),
'priority': f["Encroachment_Priority"],
'descript': f["Description"],
geometry: Geometry(f),
i++;
for (var g in wEncroach) {
attributes: {
'type': g["Type"],
'edate': DateDiff(g["Date_Found"], Date(1970, 0, 1, 0, 0, 0), "milliseconds"),
'priority': g["Encroachment_Priority"],
'descript': g["Description"],
geometry: Geometry(g),
i++;
Console(Text(int_dict));
var encroach_set = Memorize(FeatureSet(Text(int_dict)))
// Basins
var basins = Memorize(FeatureSetByPortalItem(portal, "987406d7d0614370b6493dfe58c9e62c", 0, ['District', 'Subbasin_Name'], true))
// create final featureset
var finalDict = {
fields: [
{name: "Encroach_Type", type: "esriFieldTypeString"},
{name: "Encroach_Date", type: "esriFieldTypeDate"},
{name: "Encroach_Priority", type: "esriFieldTypeString"},
{name: "Encroach_Description", type: "esriFieldTypeString"},
{name: "SubbasinName", type: "esriFieldTypeString"},
{name: "DistrictName", type: "esriFieldTypeString"},
geometryType:"esriGeometryPoint",
"wkid":102100,
"latestWkid":3857
features: [],
// intersect CMRs with basins to determine which basin each occured in
for(var e in encroach_set) {
var i_basin = First(Intersects(e, basins))
var i_basin_name = Iif(i_basin == null, "No basin", i_basin.Subbasin_Name)
var i_basin_district = Iif(i_basin == null, "No district", i_basin.District)
//add to array
Push(finalDict['features'],
{attributes:{
Encroach_Type: e['type'],
Encroach_Date: e['edate'],
Encroach_Priority: e['priority'],
Encroach_Description: e['descript'],
SubbasinName: i_basin_name,
DistrictName: i_basin_district,
Console(Text(finalDict));
return FeatureSet(Text(finalDict))
Erica
