hi @PeterMacKenzie2 -
I am attempting to do this same thing (on AGO) that you had mentioned in your initial post. But, I am getting stuck. I have followed the instructions, that you linked to but I am not sure I totally understand what goes where: <scheme>://<yourURL>/apps/dashboards/<id>#param=value.
is <id> the dashboard item id?
after #param=, is param the variable that can be renamed whatever you would like in the dashboard settings/URL paramters? Do you need to identify the feature layer ID here, or simply the field's value you are trying to have the hyperlink zoom to (in my case, a globalID to a point on the map). so, #param=<GUID>
Here is what I have tested, but am not getting any result
https://<myurl>/apps/dashboards/<dashboardID>#paramZ=<GlobalID>
where paramZ is the parameter name I created in the dashboard's settings, URL Parameters to zoom to the feature on the dashboard's map.
Am I missing something here? Thank you in advance!
Vanessa
