Transfering Attachments from a file geodatabase to another fgdb
582
10-18-2022 07:36 PM
ThaoNDP
New Contributor III
Dear All members of the Esri Community,
I am trying to transfer all photos attached to the corresponding features in a feature class of an FGDB to another FGDB using transformers in ArcGIS Data Interoperability. But this task I haven't completed because the translation failed. The photos are attached after Enable Attachments feature is enabled for that feature class. This means the Relationship Class will be automatically generated with primary keys from GlobalID.
If anyone has successfully set up and run this conversion, can you suggest to me which transformers you have configured in the workspace?
Thank you very much for any advice from you all.
Thao
BruceHarold
Hi
If you relationships are GlobalID based (we only just added support) please try this workflow:
https://community.safe.com/s/article/writing-arcgis-geodatabase-attachments
