Error Opening Batch File(s). There was an error reading the batch file(s):
8762
27
08-31-2012 06:39 AM
ScottLampley
New Contributor III
I am trying to open / view / edit a batch job file (.rbj) and get the following error:
The check will run but i cannot open it for editing...
The file in question is checking for a variety of geometry issues
This seems to have started after I upgraded from 10 to 10.1.
any ideas?
KumarBhardwaj
Occasional Contributor II
Hi Scott,
Can you please try to save that batch job with a different name and then try editing the checks and adding the data using the newly created batch job in ArcMap?
I just want to make sure that the existing batch job file is not corrupted. Also would it be possible for you to share the batch job file for testing.
Kumar
El_BoukfaouiReda
I am experimenting the same error and again it didn't help me installing my ArcGIS 10.1 Data Reviewer SP1 and its Patch 6.
I tried also to save it in another file and give it another name but still it is giving the same error.
The file is in a proper Enterprise Environment and the risk of corruption is not  maximal.
Please help me on this.
KumarBhardwaj
Please contact Esri Technical Support for this issue. They can further troubleshoot and help you in resolving this issue. You can contact Esri Support here.
maherelayyan2
I contacted ESRI for this but no action till now , anyone found a solution for this ??
MichelleJohnson
What version was the batch job created in?  What version are you opening it up in?  What kind of checks are in there?
maherelayyan2
Version 10.2.2 and i tried many types of checks like table or topology checks and it is giving the same error.
is there a recommended steps needed before saving the batch file ? like setting workspace maybe ??
MichelleJohnson
I've not heard of issues with creating and reopening the Reviewer Batch jobs in version 10.2.2.
Basic steps for creating a batch job:
  1. Add the data you want to validate in ArcMap.
  2. Open Reviewer Batch Job Manager
  3. Create a New Group
  4. Add a check
  5. Configure the check
  6. Save the batch job
  7. In Batch Validate, open the batch job
  8. Click on Validate All
  9. Run the batch job.
What's the exact error message you are receiving when you try to open the batch job? Which dialog are you opening it up in?  Batch Job Manager or Batch Validate?
maherelayyan2
gone with the same steps you put , when opening in batch validate it give
There was an exception loading the batch job , loading aborted .
when opening in batch job manager : There was an error reading the batch file
MichelleJohnson
What ArcGIS build number do you have?  What Data Reviewer build number do you have?
http://downloads2.esri.com/Support/downloads/other_/PatchFinder.exe
