Using Arc Pro 3.2.1 with the Data Reviewer extension.
In creating a list of rules for my data I am finding that the 'Feature on Feature'Ready to Use rules are working well. However when I add Ready to Use "Query Attribute" rules to my Attribute Rule list for error conditions that I know are present in the data. , Only the first "Query Attribute" rule authored and tested will find the appropriate error conditions, Any additional "Query Attribute" rules are not found by the error inspector. I have tested this in multiple ways. switching which of my 'Query Attribute" rules run first in my Attribute Rules list and the behavior seems consistent. Only the first "Query Attribute" rule runs correctly when Validating.
In the screenshot below. "Ground Check and Multiple Observations" and "Review Unknown DCA" are 2 different "Query Attributes" . If ""Ground Check and Multiple Observations" is created/added to my Attribute Rules list . It will run properly in Error Inspector, but "Review Unknown DCA" will not. If I reverse that order and define "Review Unknown DCA" before ""Ground Check and Multiple Observations" the "Review Unknown DCA" will validate correctly in error inspector and none of the "Ground Check and Multiple Observations" conditions are found by the error inspector.
Feels like a bug.
Hoping that there is some work-around that will allow me to have more than one functioning "Query Attributes" Ready to Use Rule in my list of attribute rules.
THanks for any insights
