I am using ArcGIS Desktop 10.7.1 and am encountering problems when I attempt to use custom geographic transformations.
I have a set of custom geographic transformation files (.gtf) which previously worked under ArcGIS 10.3.1. These .gtf files were located under C:\Users\<username>\AppData\Roaming\ESRI\Desktop10.3\ArcToolbox\CustomTransformations.
I migrated the same files to C:\Users\<username>\AppData\Roaming\ESRI\Desktop10.7\ArcToolbox\CustomTransformations.
Whilst the transformations appear in the relevant dropdown list in the 'Project' geoprocessing tool, when I go to select a custom transformation I receive the following error:
I thought maybe the way 10.7.1 constructs the .gtf file might be different, so I constructed a new custom transformation within 10.7.1 from scratch, but alas I still have the same difficulties.
Is this a known bug in 10.7.1, or am I doing something wrong?
