Omur,
Go to the ArcGIS Administrator. Check the Machine ID. It should list your MAC Adress, Host Name, IP Address, Domain and at least two UMN id's. If you only see one or if any feature mentioned was not identified, reinstall ArcGIS Desktop. If this is not the case, I would suggest you contact Technical Support. This could require deep troubleshooting.
