Keyboard shortcut that previously worked does not now work in ArcMap 10.4.1
I looked again at the links you sent - the one where F2 renames a selected item seems to be related to working with a table. I am not using any tables - just polygons in a feature dataset.
well, I am out of ideas and no one has chimed in and you haven't said whether mapping to another keyboard shortcut works, so you might want to contact tech support.
Thanks - support it will be - I appreciate your efforts - I have tried mapping it to another key, and still not working - again, thank you
ISSUE RESOLVED:
We discovered that a setting in:
Editor toolbar > Options > Versioning was the issue for this particular problem.
The "Automatically save changes after each edit" box was CHECKED - this is apparently by default. With this option checked, Arc10.4.1 does not respond the the "Clip..." keyboard shortcut I assigned.
When I uncheck the "Automatically save changes after each edit" box and save my .mxd, all is well - all my keyboard shortcuts work as before, even the "Clip..." command - it immediately brings up the "Clip" window as before.
Thanks, Dan for your efforts.
