questions
345
09-28-2020 05:02 PM
alinasser
Pelasse  can You help me
I have the same problem, with the "Upgrade requirement not met"
I don't understand what is this "Uninstall Programs" section, can you show me where it is ?
That would be helpfull, I'm really need to install ArcGis
thanks
DanPatterson
Windows search (bottom left)
Add/Remove Programs
If Upgrade requirement isn't met, then it means you don't have the initial version of "whatever" installed or its version isn't correct for an upgrade.  Sometimes, you just can't upgrade a version without intermediate upgrades.  In those instances, a complete uninstall of the old and an install of the new is best.
Of course, this depends on what you want to remove and what you have to install
... sort of retired...
LaureneKoman
The message can be displayed for one of the following - let's use Desktop 10.8 as the example of what you are trying to install.  you could get that message if you have Server or ArcGIS Engine installed that are NOT version 10.8.  you could also get that message if you have ArcGIS Desktop installed but it's a beta version and not a released version. Check your add/remove Programs list and see if you have other ArcGIS products already installed.
