Can you clean up or edit 3D mesh from Drone2Map
274
12-06-2023 05:29 AM
JonathanDandois
I like Drone2Map for it's integration into the rest of our Esri ecosystem, but it often produces more artifacts in 3D models than other products when working with the same dataset.
Are there ways to edit the mesh - for example removing these artifacts  - while still being able to publish it as a service?  I imagine it might need to take a workflow like: Create Mesh in Drone2Map as OBJ -> Edit in other program like Meshlab -> import OBJ and convert to SLPK -> publish?
