Walk-through of Azure Active Directory integration with ArcGIS Portal
4753
6
03-08-2021 09:01 PM
by Anonymous User
Not applicable
8 6 4,753
  1. Some of our clients might require the integration of ArcGIS Portal with Azure, here i have summarized steps on how to setup Azure with ArcGIS portal just in case you might need in the future.
  2. Sigh up Azure. Azure portal is free for 12 months. As Active Directory configuration requires to sign in as a Global Administrator, I would recommend use your personal email account to sign up instead of the Esri email address.
  3. Login in with your account.
  1. Select the Azure Active Directory item and then click Enterprise Applications from the Azure Active Directory left-hand navigation menu.
  1. Click New Application on the Enterprise Applications pane.
  1. Click Non-gallery application in the Add your own app section.
  2. Enter the name of the application in the Name textbox and then click Add.
  1. Once the application loads, click the Set up single sing on tab and then select SAML
  1. Login into your ArcGIS portal with admin, go to Organization - Settings - Security, click Get Service Provider and then save Metadata.xml file
  1. Back to the Azure Portal page, click 'Upload Metadata file' at the top of the banner, and then upload your Metadata.xml
  1. Go to SAML Signing Certificate, download 'Federation Metadata Xml'.
  1. Go to ArcGIS port Portal, Organization - Settings - Security, click Enterprise Logins visa SAML, upload your Azure metadata to portal and save changes.
  2. Go to Azure Portal, you now should be able to Test your configurations.
  1. Log off from your Portal and then click Enterprise login with your AD account. LiranSun_9-1615265841207.png
Tags (1)
6 Comments
