We are upgrading our ArcGIS server 10.2.2 to 10.3.1.
We have two SOEs that are needed once we upgrade.
I am trying to ensure that there will be no issues when I upgrade. According to ESRI I only need to remove the SOEs prior to the upgrade and then add them back after the upgrade.
My question is do I need to upgrade the ArcObjects SDK prior to upgrading the ArcGIS Server installation and adding the SOEs back? The SOE uses the SOESupport assembly which I believe comes from the SDK and that is why I was wondering if the SDK needed to be upgraded.
I am assuming that because my SOE is currently working in 10.2.2 that .NET 3.5 SP1 is installed, correct?
Thanks for any input.
Mele
