Please remove the limitation that blocks custom widgets in Portal 10.5.1 on public facing apps. We have purchased Gold Partner widgets to serve content to the public that we have now found we cannot use.
If you cannot remove the limitation of loading widgets from external sites (i would prefer a warning as opposed to a complete block), it would be acceptable to at least allow widgets that are hosted on the same domain as portal.
