In a portal collaboration with a workspace that is set to sync at scheduled intervals, the times shift an hour when daylight savings goes into effect (and also when it ends). I have to go in and manually change the start time back to the intended time of day. I have to remember to do this twice a year.
I'm setting my start time for 5AM in the portal settings. When I look at the schedule of the collaboration workspace in the REST endpoint, it is saving the start time as 9:00 UTC without any reference to my local time zone. It would be nice to have the option to have the schedule recognize the local time zone and auto-adjust for daylight savings.
I created a case with support about this. Initially, it was suggested I create an idea for this functionality. However, this is supposed to work and there is a bug associated with this.
#BUG-000138372 Scheduled Syncs in Distributed Collaborations do not update when time settings are changed on the Portal for ArcGIS machine
