Set an option to limit the size on the creation of hosted tile layer caches in portal. This would limit the size of a tile layer cache being generated on the server. In the role configuration on portal allow the admin to set a size limitation (250 MB, 500MB etc..) If the user tries to create a tile cache and the proposed size is too large a warning popup would display recommending to reduce the size by using the selected scales.
