Select All in Attribute Table in Portal
331
04-13-2021 08:24 AM
Status: Open
LaurenVigneault1
New Contributor II
When using the Attribute Table in Portal, there is no one-click option to Select All or Deselect All. The suggested workaround is to hold down shift in order to select a range of records; however, this only seems to work on a range of around 150 records. If a table has many records, it is not possible to select all of them using the Shift method because it is limited. This means that on a large table, there is essentially no way to "select all." Looking for an enhancement so that there is no limitation to the amount of records that can be selected in the Attribute Table while holding down shift.
