SQL Function to get specific vertex of SDE.ST_GEOMETRY polygon
125
3 weeks ago
Status: Open
Bud
Notable Contributor
Oracle 18c 10.7.1 EGDB:
I want to write a SQL query that has rows with the XY coordinates of each vertex of an SDE.ST_GEOMETRY polygon feature class.
I can do it for a line FC using a cross join, a numbers table, and ST_PointN:
select
    a.objectid,
    b.number_ as vertex_id,
    a.sde.st_x(sde.st_pointn(a.shape, b.number_)) as x,
    a.sde.st_y(sde.st_pointn(a.shape, b.number_)) as y
from
    infrastr.active_transportation a
cross join
    infrastr.numbers b
where
    b.number_ <= sde.st_numpoints(a.shape)
    and a.objectid = 14113
But if I run that query on a polygon FC instead of a line FC, then I get an error:
ORA-20003: ST_Geometry type must be an ST_LINESTRING or ST_MULTIPOINT type.
ORA-06512: at "SDE.ST_GEOMETRY_OPERATORS", line 2614
If I comment out the lines that use ST_PointN, then the query runs successfully:
select
    a.objectid,
    --a.sde.st_x(sde.st_pointn(a.shape, b.number_)) as x,
    --a.sde.st_y(sde.st_pointn(a.shape, b.number_)) as y
from
    infrastr.bc_polygons a
cross join
    infrastr.numbers b
where
So, that tells me that the problem is with ST_PointN. ST_PointN appears to only work for lines:
ST_PointN
ST_PointN takes an ST_LineString and an integer index and returns a point that is the nth vertex in the ST_LineString's path.
Can a function be added to ST_GEOMETRY to get a specific vertex of a polygon?
Get vertex of SDE.ST_GEOMETRY polygon using SQL
2 Comments
EdwardGause
I did the following MS SQL for my boundary on my database to get the vertices of a polygon:
SELECT a.OBJECTID,
t.number as Vertice,
a.Shape.STPointN(t.number).STX as Longitude,
a.Shape.STPointN(t.number).STY as Latitude
FROM DB1.sde.Boundary a
JOIN
      SELECT number
      join
           SELECT ROW_NUMBER() OVER (ORDER BY (SELECT NULL)) AS number
           FROM master..spt_values
      ) n on ( n.number BETWEEN 1 AND a.SHAPE.STNumPoints() )
where a.objectid = 401
) t on (t.number <= a.SHAPE.STNumPoints())
Bud
Interesting. I wonder why STPointN works for your polygon FC since the docs say it's meant for ST_LineString only.
