Currently when trying to view ArcGIS Server Manager in a small window or small screen, UI elements are rendered off screen and you have to scroll side to side to see all the information. I would like to see the UI of ArcGIS Server Manager rewritten using a responsive web design framework that supports adjusting UI elements to best fit the screen based on the size of the screen. An example of what I am looking for is ArcGIS Portal 10.8.1. At that version of ArcGIS Portal, I can easily navigate and view the content no matter the screen size.
