I assume you are referring to ACM when you say 'AWS SSL Certificate"?
I believe the way the CloudFormation templates work now, they expect you to have a certificate file provided. You could then later add an Application Load Balancer with an Amazon (ACM)-managed Certificate, if you wanted to switch to using that, but I don't think there is a way to roll one CF template that includes an ACM cert.
