Hi All,
In ArcPro, I can connect to my Azure blob storage container using the SAS token by setting the token value in the Provider Options: AZURE_STORAGE_SAS_TOKEN property.
However the 'Provider Options' values are not accessible in the UI dialog for either ArcGIS Server manager nor ArcGIS Portal. Does this mean we CAN'T use a SAS token to register the Azure blob storage container in enterprise? Maybe using the REST endpoint? So far no luck figuring out a syntax there.
When we try thru the ArcPRO UI, we get critical failure with the "Report to Esri" dialog box 😞
