Adding scale bars or units to chart symbology in ArcMap 10
399
04-18-2012 01:16 PM
DavidFrench2
I am trying to display my data using the chart (specifically the column chart) symbology via:
Properties > Symbology > Charts >Bar/Column
I have the charts displayed (2 categories per data point) and they look fine, but I'd like to add some type of scale bar or labeled axis to each chart.
Is there a way of doing this? I've tried changing the axis properties and even creating a BMP file and using a picture as the axis, but this doesn't display properly.
Anyone on here an ArcMap guru or encountered the same issues?
Any advice would be appreciated! Thanks
DavidFrench2
FYI, the charts are comparing two values, both are on a scale of 0-1, I'd just like some metric displayed that shows the relative value, as it's difficult to discern between locations based solely on vision.
Cheers
