I successfully Installed ArcGIS 10.3.1
It created site admin account successfully and when I try to create a map It gave me below error :
Invocation of RMI stub method failed: public abstract com.esri.gw.index.common.ReturnCode com.esri.gw.index.service.IndexService.updateDocument(java.lang.String,com.esri.gw.index.common.GwIndexDocument,com.esri.gw.index.common.IndexTerm,java.lang.String); nested exception is java.lang.NullPointerException
Someone can explain why is this and any solution please.
Here is portal log :
<Msg time="2015-12-15T15:12:36,371" type="WARNING" code="217064" source="Portal" process="10704" thread="1" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed="">sg>
<Msg time="2015-12-16T09:21:33,686" type="INFO" code="205005" source="Portal Admin" process="11220" thread="1" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed="">Testing connection to user store.</Msg>
<Msg time="2015-12-16T09:21:33,708" type="INFO" code="205009" source="Portal Admin" process="11220" thread="1" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed="">Identity store updated.</Msg>
<Msg time="2015-12-16T09:21:33,710" type="INFO" code="205006" source="Portal Admin" process="11220" thread="1" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed="">Testing connection to role store.</Msg>
<Msg time="2015-12-16T09:21:33,716" type="INFO" code="205009" source="Portal Admin" process="11220" thread="1" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed="">Identity stoThe web server was found to be stopped. Re-starting it.</Mre updated.</Msg>
<Msg time="2015-12-16T09:23:21,40" type="WARNING" code="217064" source="Portal" process="10704" thread="1" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed="">The web server was found to be stopped. Re-starting it.</Msg>
<Msg time="2015-12-16T09:25:01,295" type="SEVERE" code="219999" source="Sharing" process="9028" thread="13" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed=""> Unable to get item: 98371d501b8745e389268afb7ed4ba0a</Msg>
<Msg time="2015-12-16T09:25:15,157" type="SEVERE" code="219999" source="Sharing" process="9028" thread="13" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed=""> Unable to get item: 98371d501b8745e389268afb7ed4ba0a</Msg>
<Msg time="2015-12-16T09:25:22,288" type="SEVERE" code="219999" source="Sharing" process="9028" thread="13" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed=""> Unable to get item: 98371d501b8745e389268afb7ed4ba0a</Msg>
<Msg time="2015-12-16T09:25:32,678" type="SEVERE" code="219999" source="Sharing" process="9028" thread="13" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed=""> Unable to get item: 98371d501b8745e389268afb7ed4ba0a</Msg>
<Msg time="2015-12-16T09:25:39,108" type="SEVERE" code="219999" source="Sharing" process="9028" thread="13" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed=""> Unable to get item: 98371d501b8745e389268afb7ed4ba0a</Msg>
<Msg time="2015-12-16T09:25:39,110" type="SEVERE" code="219999" source="Sharing" process="9028" thread="13" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed=""> Unable to get item: 98371d501b8745e389268afb7ed4ba0a</Msg>
<Msg time="2015-12-16T09:26:45,924" type="SEVERE" code="219999" source="Sharing" process="9028" thread="13" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed=""> Unable to get item: 98371d501b8745e389268afb7ed4ba0a</Msg>
<Msg time="2015-12-16T09:27:01,916" type="SEVERE" code="219999" source="Sharing" process="9028" thread="13" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed=""> Unable to get item: 98371d501b8745e389268afb7ed4ba0a</Msg>
<Msg time="2015-12-16T09:27:03,148" type="SEVERE" code="219999" source="Sharing" process="9028" thread="13" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed=""> Unable to get item: 98371d501b8745e389268afb7ed4ba0a</Msg>
<Msg time="2015-12-16T09:27:20,635" type="SEVERE" code="219999" source="Sharing" process="9028" thread="13" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed=""> Unable to get item: 98371d501b8745e389268afb7ed4ba0a</Msg>
<Msg time="2015-12-16T09:27:37,883" type="SEVERE" code="219999" source="Sharing" process="9028" thread="13" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed=""> Unable to get item: 98371d501b8745e389268afb7ed4ba0a</Msg>
<Msg time="2015-12-16T09:27:44,25" type="SEVERE" code="219999" source="Sharing" process="9028" thread="13" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed=""> Unable to get item: 98371d501b8745e389268afb7ed4ba0a</Msg>
<Msg time="2015-12-16T09:27:54,145" type="SEVERE" code="219999" source="Sharing" process="9028" thread="13" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed=""> Unable to get item: 98371d501b8745e389268afb7ed4ba0a</Msg>
<Msg time="2015-12-16T09:28:00,549" type="SEVERE" code="219999" source="Sharing" process="9028" thread="13" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed=""> Unable to get item: 98371d501b8745e389268afb7ed4ba0a</Msg>
<Msg time="2015-12-16T09:28:12,844" type="SEVERE" code="219999" source="Sharing" process="9028" thread="13" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed=""> Unable to get item: 98371d501b8745e389268afb7ed4ba0a</Msg>
<Msg time="2015-12-16T09:29:25,720" type="SEVERE" code="219999" source="Sharing" process="9028" thread="13" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed=""> Unable to get item: 98371d501b8745e389268afb7ed4ba0a</Msg>
<Msg time="2015-12-16T09:29:32,31" type="SEVERE" code="219999" source="Sharing" process="9028" thread="13" methodName="" machine="DHQAPP51.DOTI.AE" user="" elapsed=""> Unable to get item: 1b43c6ebdf5b47178a510d7d85d19208</Msg>
