I am using arcpy.UploadServiceDefinition_server to publish an MXD to an on-premise Portal for ArcGIS 10.4.1 (ArcGIS Server 10.4.1 is installed and federated with the portal).
I have created a script based on this example. I have also been using this documentation (especially example 3) to guide me.
My goal is to share the published services with a group defined on the Portal server, but so far every time I publish, the feature layer is "Not Shared".
Here is an example of my UploadServiceDefinition call:
arcpy.UploadServiceDefinition_server(
"myMapService.sd", # in_sd_file
"myServerConnection.ags", # in_server
"newServiceName", # in_service_name
"", # in_cluster
"", # in_folder_type
"", # in_folder
"STARTED", # in_startupType
"OVERRIDE_DEFINITION", # in_override
"SHARE_ONLINE", # in_my_contents
"PRIVATE", # in_public
"NO_SHARE_ORGANIZATION", # in_organization
"My Group" # in_groups
I have also tried changing the in_groups parameters to a list, like so:
"", # in_cluster
"", # in_folder
["My Group"] # in_groups
But, so far, no matter what parameters I supply that seem to apply to sharing, the feature layer is always "Not Shared" after publishing.
Am I missing something fundamental? If anyone can point me toward the light I would be most appreciative.
