I'm working in the new Map Viewer in Portal and I would like to create a custom label or expression I can use in the popup window. I didn't see an option under labeling for anything custom so may have to be popup. I am not an expert at writing expressions so need some help.
This is my expression from ArcMap and would like it to look the same in Portal.
[LAND_VALUE_CURRENT] &vbCrLf& [PARCEL_ACREAGE] & " Acs" & vbCrLf& "$ "& Round ( [LAND_VALUE_CURRENT] / [PARCEL_ACREAGE], 0) & " Per Acre"
On the map, it looks like this:
