Do you know of any ESRI supported options to move (Not) just the content of a user's Portal for ArcGIS content folder, but move the folder itself to a different portal user?
2660
04-29-2016 10:24 AM
BillFox
MVP Frequent Contributor
Same question about ArcGIS for Server folders & services.
v10.3.1 or v10.4
ArcGIS Ideas Added A New Post To Promote:
"Be able to move folders in Portal for ArcGIS from one user’s content to a different users content"
As the Administrator you have the power to control everything within your portal.
So, please add the ability to move (Not) just the content of a user's portal content folder, but move the folder itself with its content to a different portal user's content folder.
- And it not effect the webmap, services, etc.
This would be similar to to change ownership functionality already included with Portal for ArcGIS.
This will improve the process when employees leave, and you need to move or re-assign their content.
It will also help with
a change in the publishing workflow.
https://c.na9.visual.force.com/apex/ideaList?c=09a300000004xET&sort=recent
-Bill
MichaelVolz
Esteemed Contributor
There is a company called GeoJobe that has produced software that might help with this task.  I would just do a google search on geojobe.  Some tools are free and others you will need to pay for.  Good luck.
