Enter SAML users from file
184
2 weeks ago
TychoGranville
Occasional Contributor II
We can successfully add users manually, so that part's not a problem.
I grabbed the csv template from my Portal (10.9.1) which has this (in Notepad++ for reference):
Email,Role,User Type,First Name,Last Name,Username
Various ESRI help docs list user type and roles as:
role—This is the role the organization-specific login will have in the organization. Valid role values are viewer, user, publisher, data editor, admin, or <custom_role_name>
Some examples of user type id values for the standard user types include viewerUT, editorUT, fieldworkerUT, creatorUT, GISProfessionalBasicUT, GISProfessionalStdUT, and GISProfessionalAdvUT
My csv file ends up with:
Portal throws this:
 viewer/viewer works (if I drop the UT), where is a list of the correctly spelled/capitalized/etc. strings for Role and User Type? I'm tired of trying to guess.
MichaelJenkins
Occasional Contributor III
You can just use the User Types as listed in your Org Licenses section.  "Creator", "Editor", "Mobile Worker", and "Viewer" for example.
GISP
MichaelJenkins
GISP
TychoGranville
Bah. I flipped the user and role fields in my head (matching the order on the screen, not in the csv). In my defense, I did have to remove the UT portion of the string the help doc said it needed...
Thank you for the quick reply.
Tycho
