Hello I am trying to use the edit widget in experience builder to add new features and or table to a related feature.
So i have a hosted feature service with a Roof polygon layer, Roof Issue point layer and Roof Inspections table
Roof Issue layer is related to Roof via globalid (Roof) and parentguid (Roof Issue)
and
Roof Inspections is related to Roof via globalid (roof) and parentguid (Roof Inspections)
I want to be able to create/add a roof inspections and or roof issue based on the relate.
also its a 1 to many relationship that was created in pro and published to portal
So in my field maps which is working perfectly fine you select a Roof polygon and you can choose to edit/update or add/create a Roof Inspection or Roof Issue
I saw this article regarding map viewer which I assume can translate to the edit widget in experience builder but the article was meant for Arcgis online, now I know these features were also supposed to be updated at the end of 2023 for 11.2 portal so I shouldn't be having any issues
Introducing Related Record Editing in Map Viewer (esri.com)
