Hi, I am Korea Esri User.
I'm asking for your opinion because I have a question.
I'm going to download the content from the source portal and move it to another portal.
Is there a way?
Downloading from the portal is possible through hosting layer, and if i open it on ArcGIS Pro, it is difficult to download because it is a simple data reference.
It is not clear from your post how the source data is stored. Please confirm which of the following it is:
Thanks
Thank you for answering my question.
The published data is stored in the Data hosted on ArcGIS Portal. Data created specifically by Portal.
Hi @Jin-taeKim
Thanks for confirming your data is hosted on Portal.
You have multiple options:
Hope this helps
Dear @Richard_Purkis
Unfortunately, I actually tried all three options you mentioned.
1. When using File Geodatabase format, Failed appears during the download process.
Is it because there are too many attached photos?? I think it's about more than 10GB.
2. In the case of cloning, the data source is considered as the source portal, so if there is a problem with the source portal, the cloned data will also be affected.
3. I also tried the AGO assistant. The data source is set to the source portal, and, of course, it is not available if change the source url.
Is there any other way???
Thank you for listening to my concerns during your busy time.
Hello @Jin-taeKim
I found the below document for cloning content between two portals.
Thank you for sharing my concerns.
I tried clone using Python, but I will try it again through the document you sent me.
Thank you.
Have a nice day
HI @Jin-taeKim
have you tried to clone the content using python? were you succeeded?
@nabaz-gharib
Sorry for the late answer
I succeeded by cloning, but it was not separated from the existing Portal information. So I adopted a different method.
