Network Analyst Portal - NAServer - Add route details
315
11-16-2023 08:54 AM
byander
Hello people,
I created a network using my roads database and added some cost attributes to view the table details like the lengths for different kinds of classes of roads (asphalt and dirt).
In ArcGIS Pro, I marked these attributes on the button "Accumulate Cost Attributes" in the "Travel Settings" tab. So, after generating the route, I can see the total lengths for asphalt and dirt on the attribute table.
I published the route to the ArcGIS Enterprise Portal and configured the Utilities Services / Route / Url NAServer.
When I use the Directions widget to trace a route and save, the attributes I created on ArcGIS Pro not show.
Is there any way to show these custom attributes in route details?
For my job, showing the route directions isn't important (unfortunately I have not found an option to disable this) but showing the total lengths for asphalt and dirt it's essential to use in ArcGIS Enterprise Portal.
Thank's for any help.
Tags (3)
