Portal for ArcGIS can only use Port 80 is limiting
2405
04-30-2015 05:58 AM
BradfordFolta
To use Portal for ArcGIS, the documentation states the Web Adaptor must be used, and that it can only communicate using Port 80 or Port 443 (SSL). This is extremely limiting - our organization is already using Port 80 for other applications so that is NOT an option. The alternative of using SSL or Port 443 is going to cost us a lot more for a CA Certificate and is really not wanted. Why can't the web adaptor be flexible enough to be used on at least several different ports?
