I have highly available Portal stack and I've noticed in our failover server, there is large quantity of folders with the prefix "db" and a hash that follows in the "arcgisportal" directory. See the image below, they are consuming are large amount of disk space!
Should portal be cleaning these up?
Is it safe to manually delete these or is there script that should be run?
Many thanks!
