Validate Relational Datastore from ArcGIS Server Administrator = 'invalid token'
1346
02-17-2022 09:30 AM
TrinaNair
Installed Enterprise ArcGIS 10.9.1.   Had validated the datastore with ArcGIS Server manager.   Month later, couldn't publish to the datastore.  Datastore unable to validate.  Also checked Server Administrator - 'Invalid Token'.  Tried unregistering and re-registering the Datastore.  DescribeDatastore - the "Portal for ArcGIS URL" is empty.  Also tried a test to run 'Updatelicense' - unable to generate a token.
Tried uninstalling and reinstalling the Datastore (was going to restore from backup).  Same result.  Checked Federation it validates okay.  Thanks
Tags (3)
NaveenK
I would quickly check if the ADMIN URL from Portal administrator directory page is showing up properly.
I had a similar issue that Owning URL was missing and the solution was to update the ADMIN URL from ArcGIS server administrator directory.
Regards,
Naveen
NaveenK
Regards,
Naveen
TrinaNair
Naveen - Thanks you so much.  That was totally it.  I was searching all over the place for that.  Thank you!!!!
