Vector Tile option in Layer Type is not available
962
11-13-2017 09:09 PM
RaviKiran
Hi All,
Could able to publish Vector tile service using geoprocessing service "Create Vector Tile Package" and able to add it to Portal for ArcGIS, so far no issues. However, as per the documentation, I couldn't able to find "Vector Tile" in "Layer Type" option while publishing as a web layer.
Reason for looking into this option is to set the custom tiling scheme which is not available in current geoprocessing options unlike documented in ESRI help. Tried to load custom scales to map and set as default in map properties, but still while publishing Vector tile service, taking ArcGIS Online tiling scheme as default. We have created custom tiling scheme using geoprocessing tool but unable to configure it manually in ArcGIS Pro.
Is there any patch required to install on top of ArcGIS Pro1.3? Currently, we are having ArcGIS Pro 1.3 and Portal for ArcGIS 10.4 version.
Regards,
Ravi
GISSupport3
Not possible to do in Portal for ArcGIS 10.4
