The Portal Installation has been updated from 10.7.1 to 10.8.1.
I am not sure if webgisdr worked after update. But now I got the following error in the webgisdr log:
2021-02-26 12:53:32 ERROR [main] com.esri.arcgis.webgis.client.WebGISDR - Failed to generate token for Portal for ArcGIS. Verify that the credentials you entered are correct. Check the WebGIS DR utility logs and the Portal for ArcGIS logs for more information.
I double checked the password 🙂
In the logback.xml in the webgis directory I set the loglevel to DEBUG. After that I saw the following exception.
Caused by: java.lang.RuntimeException: The response returned HTTP status code 404. Requested URL: https://[fqdn of internal portal url]:7443/arcgis/portaladmin/sharing/rest/generateToken
I got the same response in a browser.
The url to the generateToken endpoint is:
https://[fqdn of internal portal url]:7443/arcgis/sharing/rest/generateToken
without the portaladmin directory
Did I miss something?
Thanks!
