What does '-1' refer to in the 'Max Token Expiration Minutes' on Portal?
4231
03-24-2016 10:01 AM
MattJones
Does anyone know what the '-1' refers to in the 'Max Token Expiration Minutes' on Portal? I went to change this value following these instructions and expected it to be 20,160 (2 weeks) - Specify the default token expiration time—Portal for ArcGIS  (10.4) | ArcGIS for Server
Does '-1' mean there is no expiration or does it mean the default of two weeks?
Matt
MichaelSchoelen
Can someone please address this?
JeffreySutherland
Hi Michael and Matt,
In Portal for ArcGIS, the '-1' value for 'Max Token Expiration Minutes' represents a default of two weeks (or 20,160 minutes) validity for access tokens.
In addition to being the default value, 2 weeks also represents the max expiration value acceptable for access tokens - attempting to update this value to anything greater than 20,160 will not be accepted by the software. This is not explicitly stated in the Portal documentation - we will work to improve the info on the referenced doc page in future releases: Specify the default token expiration time—Portal for ArcGIS (10.6) | ArcGIS Enterprise.
Let me know if this helps.
Jeff
by Anonymous User
Not applicable
Are there any options around this? To get a token generated for longer than 2 weeks?
JeffreySutherland
Hi @Anonymous User ,
Apologies for the delayed response.
Unfortunately, there is no workaround for this. Two weeks is the max limit token expiration for a regular or oauth access token.
Jeff
