ArcGIS 10.2 Publishing Tools Error
14288
10
08-19-2013 03:07 PM
YungKaiChin
I am testing ArcGIS 10.2.
I am trying to publish a web service from ArcGIS 10.2 Desktop to ArcGIS 10.2 Server, but I got an error message:
"The server is not ready for publishing.
Please check if the Publishing Tools on the server
(System/PublishingTools) are started."
The message appeared when I clicked Publish on Service Editor.
I used Manager to check the services, and the tools were running (started).
Any input, suggestion, solution will be appreciated.
Thanks.
For the test purpose, I turned off the firework, so it shouldn't be the cause.
Under Admin tools/Services, ArcGIS Server is also running.
Anas_HaniAL-Shamasneh
Hi;
i try this solution and it is good
double click to the System/Publishing Tools on arcmap then put login to arcgis server
please give me feedback if this solution true
