Here's the Sanitized Log Report
DeploySiteWithAutomationAGJob started at 16-Jan-2024-T12-59-36
Started Site Deployment to gis
Validating Azure Resource Manager(ARM) template and parameters used for deployment
Azure Resource Manager (ARM) Template used for deployment is valid
Starting deployment with name 'azuredeploy-0116-1859'
Operation on resource 'generateSSLCertificatesCustomExtension-azuredeploy-0116-1859' succeeded
Operation on resource 'JumpBox' succeeded
Operation on resource 'WebGIS-Pri' succeeded
Operation on resource 'JumpBox-nic' succeeded
Operation on resource 'pid-b32fa876-02f4-44e8-a554-531c00899e56' succeeded
Operation on resource 'PublicIP-RDP' succeeded
Operation on resource 'AvailabilitySet-BaseDeployment' succeeded
Operation on resource 'WebGIS-Pri-nic' succeeded
Operation on resource 'fetchIpAddress-azuredeploy-0116-1859' succeeded
Operation on resource 'WebGIS-Pri/DSCConfiguration' is in progress
Tracking Extension 'DSCConfiguration' execution on virtual machine 'WebGIS-Pri'
[01/16/2024 11:09:40] Looking for the definition of the configuration function.
[01/16/2024 11:09:40] Executing C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\bin\..\DSCWork\DSC.0\BaseDeploymentSingleTierConfiguration.ps1
[01/16/2024 11:10:19] Preparing configuration arguments and configuration data.
[01/16/2024 11:10:19] Created encryption certificate 53F13E138BFB426607C5E56E1AC91F6D6AD8811D
[01/16/2024 11:10:19] Adding encryption certificate 53F13E138BFB426607C5E56E1AC91F6D6AD8811D to the configuration data
[01/16/2024 11:10:19] Creating MOF files.
[01/16/2024 11:10:19] Executing the configuration function to generate the MOF files.
[01/16/2024 11:10:54] Meta configuration found. Injecting Thumbprint.
[01/16/2024 11:10:54] CertificateID not present in existing meta configuration; inserting 53F13E138BFB426607C5E56E1AC91F6D6AD8811D.
[01/16/2024 11:10:54] Verifying metaconfiguration for reboot information...
[01/16/2024 11:10:54] Backing up C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\DSCWork\DSC.0\BaseDeploymentSingleTierConfiguration\localhost.meta.mof
[01/16/2024 11:10:54] No match for RegistrationKey found in the meta mof file
[01/16/2024 11:10:54] WMF 5 or newer, Injecting RebootNodeIfNeeded = False and ActionAfterReboot = "StopConfiguration"
[01/16/2024 11:10:54] Executing Set-DscLocalConfigurationManager...
[01/16/2024 11:10:57] Settings handler status to 'transitioning' (C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\Status\0.status)
[01/16/2024 11:10:59] Settings handler status to 'transitioning' (C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\Status\0.status)
[01/16/2024 11:10:59] Get-DscLocalConfigurationManager:
ActionAfterReboot : StopConfiguration
AgentId : 40BE19DA-79E9-11EE-ABB6-0022482351BC
AllowModuleOverWrite : False
CertificateID : 53F13E138BFB426607C5E56E1AC91F6D6AD8811D
ConfigurationDownloadManagers : {}
ConfigurationID :
ConfigurationMode : ApplyOnly
ConfigurationModeFrequencyMins : 15
Credential :
DebugMode : {NONE}
DownloadManagerCustomData :
DownloadManagerName :
LCMCompatibleVersions : {1.0, 2.0}
LCMState : Idle
LCMStateDetail :
LCMVersion : 2.0
StatusRetentionTimeInDays : 10
SignatureValidationPolicy : NONE
SignatureValidations : {}
MaximumDownloadSizeMB : 500
PartialConfigurations :
RebootNodeIfNeeded : False
RefreshFrequencyMins : 30
RefreshMode : PUSH
ReportManagers : {}
ResourceModuleManagers : {}
PSComputerName :
[01/16/2024 11:10:59] Executing Start-DscConfiguration...
[01/16/2024 12:15:21] Settings handler status to 'transitioning' (C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\Status\0.status)
[01/16/2024 12:15:21] Updating execution status (HKLM:\SOFTWARE\Microsoft\Azure\DSC\2.83.5\Status)
[01/16/2024 12:15:21] LCM state is PendingConfiguration
[01/16/2024 12:16:22] DSC configuration completed.
[01/16/2024 12:16:22] Resetting metaconfiguration...
[01/16/2024 12:16:22] Restoring C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\DSCWork\DSC.0\BaseDeploymentSingleTierConfiguration\localhost.meta.mof.bk...
[01/16/2024 12:16:22] Executing Set-DscLocalConfigurationManager...
[01/16/2024 12:16:22] Settings handler status to 'transitioning' (C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\Status\0.status)
[01/16/2024 12:16:25] Settings handler status to 'transitioning' (C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\Status\0.status)
[01/16/2024 12:16:25] Get-DscLocalConfigurationManager:
ActionAfterReboot : ContinueConfiguration
ConfigurationID :
Credential :
DebugMode : {NONE}
LCMState : PendingConfiguration
LCMStateDetail :
LCMVersion : 2.0
RebootNodeIfNeeded : True
RefreshMode : PUSH
ReportManagers : {}
PSComputerName :
[01/16/2024 12:16:25] Settings handler status to 'error' (C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\Status\0.status)
[01/16/2024 12:15:20] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Response:- {"error":{"code":400,"message":"Invalid administrator username or password specified. Verify the username and password are correct and try again.","details":["You are not authorized to access this information","Invalid credentials"]}}
[01/16/2024 12:15:20] [VERBOSE] [WebGIS-Pri]: LCM: [ End Set ] [[ArcGIS_Federation]Federate] in 62.3200 seconds.
[01/16/2024 12:15:20] [ERROR] PowerShell DSC resource ArcGIS_Federation failed to execute Set-TargetResource functionality with error message: [ERROR]:- Federation Failed after multiple attempts. Error:- @{code=400; message=Invalid administrator username or password specified. Verify the username and password are correct and try again.; details=System.Object[]}
[01/16/2024 12:15:20] [ERROR] The SendConfigurationApply function did not succeed.
[01/16/2024 12:15:20] [VERBOSE] Operation 'Invoke CimMethod' complete.
[01/16/2024 12:15:20] [VERBOSE] Time taken for configuration job to complete is 3860.348 seconds
[01/16/2024 12:16:22] [VERBOSE] Performing the operation "Start-DscConfiguration: SendMetaConfigurationApply" on target "MSFT_DSCLocalConfigurationManager".
[01/16/2024 12:16:22] [VERBOSE] Perform operation 'Invoke CimMethod' with following parameters, ''methodName' = SendMetaConfigurationApply,'className' = MSFT_DSCLocalConfigurationManager,'namespaceName' = root/Microsoft/Windows/DesiredStateConfiguration'.
[01/16/2024 12:16:23] [VERBOSE] An LCM method call arrived from computer WebGIS-Pri with user sid S-1-5-18.
[01/16/2024 12:16:23] [VERBOSE] [WebGIS-Pri]: LCM: [ Start Set ]
[01/16/2024 12:16:23] [VERBOSE] [WebGIS-Pri]: LCM: [ Start Resource ] [MSFT_DSCMetaConfiguration]
[01/16/2024 12:16:23] [VERBOSE] [WebGIS-Pri]: LCM: [ Start Set ] [MSFT_DSCMetaConfiguration]
[01/16/2024 12:16:23] [VERBOSE] [WebGIS-Pri]: LCM: [ End Set ] [MSFT_DSCMetaConfiguration] in 0.0190 seconds.
[01/16/2024 12:16:23] [VERBOSE] [WebGIS-Pri]: LCM: [ End Resource ] [MSFT_DSCMetaConfiguration]
[01/16/2024 12:16:23] [VERBOSE] [WebGIS-Pri]: LCM: [ End Set ] in 0.0540 seconds.
[01/16/2024 12:16:23] [VERBOSE] Operation 'Invoke CimMethod' complete.
[01/16/2024 12:16:23] [VERBOSE] Set-DscLocalConfigurationManager finished in 0.171 seconds.
[01/16/2024 13:01:33] Attempting to grab mutex DscExtensionHandler_Lock for sequence number 1
[01/16/2024 13:01:33] Acquired lock for extension instance for sequence number 1
[01/16/2024 13:01:33] Attempting to acquire extension lock
[01/16/2024 13:01:33] lock does not exist: begin processing
[01/16/2024 13:01:33] Starting DSC Extension ...
[01/16/2024 13:01:33] Getting handler execution status HKLM:\SOFTWARE\Microsoft\Azure\DSC\2.83.5\Status ...
[01/16/2024 13:01:33] Updating execution status (HKLM:\SOFTWARE\Microsoft\Azure\DSC\2.83.5\Status)
[01/16/2024 13:01:33] Transitioning to DataValidation state ...
[01/16/2024 13:01:33] Settings handler status to 'transitioning' (C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\Status\1.status)
[01/16/2024 13:01:33] Retrieving system information ...
[01/16/2024 13:01:36] OS Version : 10.0
[01/16/2024 13:01:36] Server OS : True
[01/16/2024 13:01:36] 64-bit OS : True
[01/16/2024 13:01:36] PS Version : 5.1.20348.2031
[01/16/2024 13:01:36] Validating user provided settings for the DSC Extension Handler ...
[01/16/2024 13:01:36] Reading handler settings from C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\RuntimeSettings\1.settings
[01/16/2024 13:01:36] Found protected settings on Azure VM. Decrypting.
[01/16/2024 13:01:38] Updating user preference for Data Collection ......
[01/16/2024 13:01:38] Get DSC Extension Handler install status ...
[01/16/2024 13:01:38] Status: Installed
[01/16/2024 13:01:38] Updating execution status (HKLM:\SOFTWARE\Microsoft\Azure\DSC\2.83.5\Status)
[01/16/2024 13:01:38] Transitioning to ProcessConfiguration state ...
[01/16/2024 13:01:38] Getting handler execution status HKLM:\SOFTWARE\Microsoft\Azure\DSC\2.83.5\Status ...
[01/16/2024 13:01:38] Settings handler status to 'transitioning' (C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\Status\1.status)
[01/16/2024 13:01:38] Configuration URL: https://gisstorage.blob.core.windows.net/arcgisrg-stageartifacts/DSC.zip
[01/16/2024 13:01:38] Configuration Script: BaseDeploymentSingleTierConfiguration.ps1
[01/16/2024 13:01:38] Configuration Function: BaseDeploymentSingleTierConfiguration
[01/16/2024 13:01:38] Creating Working directory: C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\bin\..\DSCWork\DSC.1
[01/16/2024 13:01:38] Downloading configuration package
[01/16/2024 13:01:38] Downloading https://gisstorage.blob.core.windows.net/arcgisrg-stageartifacts/DSC.zip to C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\bin\..\DSCWork\DSC.1\DSC.zip
[01/16/2024 13:01:39] Extracting DSC.zip
[01/16/2024 13:01:41] Installing custom DSC resource modules to C:\Program Files\WindowsPowerShell\Modules
[01/16/2024 13:01:41] Installing custom DSC resource module ArcGIS
[01/16/2024 13:01:41] DSC resource module ArcGIS already exists. Removing it first ...
[01/16/2024 13:01:41] Copying C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\DSCWork\DSC.1\ArcGIS to C:\Program Files\WindowsPowerShell\Modules\ArcGIS ...
[01/16/2024 13:01:41] Looking for the definition of the configuration function.
[01/16/2024 13:01:41] Executing C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\bin\..\DSCWork\DSC.1\BaseDeploymentSingleTierConfiguration.ps1
[01/16/2024 13:02:14] Preparing configuration arguments and configuration data.
[01/16/2024 13:02:14] Adding encryption certificate 53F13E138BFB426607C5E56E1AC91F6D6AD8811D to the configuration data
[01/16/2024 13:02:14] Creating MOF files.
[01/16/2024 13:02:14] Executing the configuration function to generate the MOF files.
[01/16/2024 13:02:50] Meta configuration found. Injecting Thumbprint.
[01/16/2024 13:02:50] CertificateID not present in existing meta configuration; inserting 53F13E138BFB426607C5E56E1AC91F6D6AD8811D.
[01/16/2024 13:02:50] Verifying metaconfiguration for reboot information...
[01/16/2024 13:02:50] Backing up C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\DSCWork\DSC.1\BaseDeploymentSingleTierConfiguration\localhost.meta.mof
[01/16/2024 13:02:50] No match for RegistrationKey found in the meta mof file
[01/16/2024 13:02:50] WMF 5 or newer, Injecting RebootNodeIfNeeded = False and ActionAfterReboot = "StopConfiguration"
[01/16/2024 13:02:50] Executing Set-DscLocalConfigurationManager...
[01/16/2024 13:02:50] Settings handler status to 'transitioning' (C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\Status\1.status)
[01/16/2024 13:02:53] Settings handler status to 'transitioning' (C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\Status\1.status)
[01/16/2024 13:02:53] Get-DscLocalConfigurationManager:
ConfigurationID :
Credential :
DebugMode : {NONE}
LCMStateDetail :
LCMVersion : 2.0
RefreshMode : PUSH
ReportManagers : {}
PSComputerName :
[01/16/2024 13:02:53] Executing Start-DscConfiguration...
[01/16/2024 13:02:51] [VERBOSE] Perform operation 'Invoke CimMethod' with following parameters, ''methodName' = SendMetaConfigurationApply,'className' = MSFT_DSCLocalConfigurationManager,'namespaceName' = root/Microsoft/Windows/DesiredStateConfiguration'.
[01/16/2024 13:02:51] [VERBOSE] An LCM method call arrived from computer WebGIS-Pri with user sid S-1-5-18.
[01/16/2024 13:02:51] [VERBOSE] The -Force option was specified with the Stop operation. The current configuration has been successfully cancelled.
[01/16/2024 13:02:51] [VERBOSE] [WebGIS-Pri]: LCM: [ Start Set ]
[01/16/2024 13:02:51] [VERBOSE] [WebGIS-Pri]: LCM: [ Start Set ] [MSFT_DSCMetaConfiguration]
[01/16/2024 13:02:51] [VERBOSE] [WebGIS-Pri]: LCM: [ Start Resource ] [MSFT_DSCMetaConfiguration]
[01/16/2024 13:02:51] [VERBOSE] [WebGIS-Pri]: LCM: [ End Set ] [MSFT_DSCMetaConfiguration] in 0.0260 seconds.
[01/16/2024 13:02:51] [VERBOSE] [WebGIS-Pri]: LCM: [ End Resource ] [MSFT_DSCMetaConfiguration]
[01/16/2024 13:02:51] [VERBOSE] [WebGIS-Pri]: LCM: [ End Set ] in 0.0650 seconds.
[01/16/2024 13:02:51] [VERBOSE] Operation 'Invoke CimMethod' complete.
[01/16/2024 13:02:51] [VERBOSE] Set-DscLocalConfigurationManager finished in 0.238 seconds.
[01/16/2024 13:03:51] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Site Admin Url:- https://gis..org/server Service Url:- https://gis..org/server
[01/16/2024 13:03:51] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Federated Server with Admin URL https://gis..org/server does not exist
[01/16/2024 13:03:51] [VERBOSE] [WebGIS-Pri]: LCM: [ End Test ] [[ArcGIS_Federation]Federate] in 0.1750 seconds.
[01/16/2024 13:03:51] [VERBOSE] [WebGIS-Pri]: LCM: [ Start Set ] [[ArcGIS_Federation]Federate]
[01/16/2024 13:03:51] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Get Portal Token from Deployment 'WebGIS-Pri.z54riog0hfiednzhowhdpnkgyh.gx.internal.cloudapp.net'
[01/16/2024 13:03:52] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Site Admin Url:- https://gis..org/server Service Url:- https://gis..org/server
[01/16/2024 13:03:52] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Could not find a federated server that is the hosting server and whose URL matches expected values
[01/16/2024 13:03:52] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Federated Server with Admin URL https://gis..org/server does not exist
[01/16/2024 13:03:52] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Federation of Server Attempt 1
[01/16/2024 13:03:52] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Federation EndPoint:- https://WebGIS-Pri.z54riog0hfiednzhowhdpnkgyh.gx.internal.cloudapp.net:7443/arcgis/portaladmin/feder...
[01/16/2024 13:03:52] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Referer:- https://WebGIS-Pri.z54riog0hfiednzhowhdpnkgyh.gx.internal.cloudapp.net:7443/arcgis
[01/16/2024 13:03:52] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Federation Parameters:- url:- https://gis..org/server adminUrl = https://gis..org/server
[01/16/2024 13:03:52] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] POST https://webgis-pri.z54riog0hfiednzhowhdpnkgyh.gx.internal.cloudapp.net:7443/arcgis/portaladmin/feder... with 456-byte payload
[01/16/2024 13:03:52] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] received 234-byte response of content type application/json;charset=UTF-8
[01/16/2024 13:03:52] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Response:- {"error":{"code":400,"message":"Invalid administrator username or password specified. Verify the username and password are correct and try again.","details":["You are not authorized to access this information","Invalid credentials"]}}
[01/16/2024 13:03:52] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] [ERROR]:- Federation returned error. Error:- @{code=400; message=Invalid administrator username or password specified. Verify the username and password are correct and try again.; details=System.Object[]}
[01/16/2024 13:03:52] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Attempt [1] Failed. Retrying after 30 seconds!
[01/16/2024 13:04:22] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Federation of Server Attempt 2
[01/16/2024 13:04:22] Settings handler status to 'transitioning' (C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\Status\1.status)
[01/16/2024 13:04:54] Settings handler status to 'transitioning' (C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\Status\1.status)
[01/16/2024 13:04:22] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Federation Parameters:- url:- https://gis..org/server adminUrl = https://gis..org/server
[01/16/2024 13:04:22] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] POST https://webgis-pri.z54riog0hfiednzhowhdpnkgyh.gx.internal.cloudapp.net:7443/arcgis/portaladmin/feder... with 456-byte payload
[01/16/2024 13:04:23] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] received 234-byte response of content type application/json;charset=UTF-8
[01/16/2024 13:04:23] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Response:- {"error":{"code":400,"message":"Invalid administrator username or password specified. Verify the username and password are correct and try again.","details":["You are not authorized to access this information","Invalid credentials"]}}
[01/16/2024 13:04:23] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] [ERROR]:- Federation returned error. Error:- @{code=400; message=Invalid administrator username or password specified. Verify the username and password are correct and try again.; details=System.Object[]}
[01/16/2024 13:04:23] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Attempt [2] Failed. Retrying after 30 seconds!
[01/16/2024 13:04:53] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Federation of Server Attempt 3
[01/16/2024 13:04:53] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Federation EndPoint:- https://WebGIS-Pri.z54riog0hfiednzhowhdpnkgyh.gx.internal.cloudapp.net:7443/arcgis/portaladmin/feder...
[01/16/2024 13:04:53] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Referer:- https://WebGIS-Pri.z54riog0hfiednzhowhdpnkgyh.gx.internal.cloudapp.net:7443/arcgis
[01/16/2024 13:04:53] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Federation Parameters:- url:- https://gis..org/server adminUrl = https://gis..org/server
[01/16/2024 13:04:53] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] POST https://webgis-pri.z54riog0hfiednzhowhdpnkgyh.gx.internal.cloudapp.net:7443/arcgis/portaladmin/feder... with 456-byte payload
[01/16/2024 13:04:53] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] received 234-byte response of content type application/json;charset=UTF-8
[01/16/2024 13:04:53] [VERBOSE] [WebGIS-Pri]: [[ArcGIS_Federation]Federate] Response:- {"error":{"code":400,"message":"Invalid administrator username or password specified. Verify the username and password are correct and try again.","details":["You are not authorized to access this information","Invalid credentials"]}}
[01/16/2024 13:04:53] [VERBOSE] [WebGIS-Pri]: LCM: [ End Set ] [[ArcGIS_Federation]Federate] in 61.9090 seconds.
[01/16/2024 13:04:53] [ERROR] PowerShell DSC resource ArcGIS_Federation failed to execute Set-TargetResource functionality with error message: [ERROR]:- Federation Failed after multiple attempts. Error:- @{code=400; message=Invalid administrator username or password specified. Verify the username and password are correct and try again.; details=System.Object[]}
[01/16/2024 13:04:53] [ERROR] The SendConfigurationApply function did not succeed.
[01/16/2024 13:04:53] [VERBOSE] Operation 'Invoke CimMethod' complete.
[01/16/2024 13:04:53] [VERBOSE] Time taken for configuration job to complete is 119.429 seconds
[01/16/2024 13:04:54] Updating execution status (HKLM:\SOFTWARE\Microsoft\Azure\DSC\2.83.5\Status)
[01/16/2024 13:04:54] LCM state is PendingConfiguration
[01/16/2024 13:05:55] DSC configuration completed.
[01/16/2024 13:05:55] Resetting metaconfiguration...
[01/16/2024 13:05:55] Restoring C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\DSCWork\DSC.1\BaseDeploymentSingleTierConfiguration\localhost.meta.mof.bk...
[01/16/2024 13:05:55] Executing Set-DscLocalConfigurationManager...
[01/16/2024 13:05:55] Settings handler status to 'transitioning' (C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\Status\1.status)
[01/16/2024 13:05:56] Settings handler status to 'transitioning' (C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\Status\1.status)
[01/16/2024 13:05:56] Get-DscLocalConfigurationManager:
ConfigurationID :
Credential :
DebugMode : {NONE}
LCMStateDetail :
LCMVersion : 2.0
RefreshMode : PUSH
ReportManagers : {}
PSComputerName :
[01/16/2024 13:05:56] Settings handler status to 'error' (C:\Packages\Plugins\Microsoft.Powershell.DSC\2.83.5\Status\1.status)
[01/16/2024 13:05:55] [VERBOSE] Performing the operation "Start-DscConfiguration: SendMetaConfigurationApply" on target "MSFT_DSCLocalConfigurationManager".
[01/16/2024 13:05:55] [VERBOSE] Perform operation 'Invoke CimMethod' with following parameters, ''methodName' = SendMetaConfigurationApply,'className' = MSFT_DSCLocalConfigurationManager,'namespaceName' = root/Microsoft/Windows/DesiredStateConfiguration'.
[01/16/2024 13:05:55] [VERBOSE] An LCM method call arrived from computer WebGIS-Pri with user sid S-1-5-18.
[01/16/2024 13:05:55] [VERBOSE] [WebGIS-Pri]: LCM: [ Start Set ]
[01/16/2024 13:05:55] [VERBOSE] [WebGIS-Pri]: LCM: [ Start Resource ] [MSFT_DSCMetaConfiguration]
[01/16/2024 13:05:55] [VERBOSE] [WebGIS-Pri]: LCM: [ Start Set ] [MSFT_DSCMetaConfiguration]
[01/16/2024 13:05:55] [VERBOSE] [WebGIS-Pri]: LCM: [ End Set ] [MSFT_DSCMetaConfiguration] in 0.0190 seconds.
[01/16/2024 13:05:55] [VERBOSE] [WebGIS-Pri]: LCM: [ End Resource ] [MSFT_DSCMetaConfiguration]
[01/16/2024 13:05:55] [VERBOSE] [WebGIS-Pri]: LCM: [ End Set ] in 0.0580 seconds.
[01/16/2024 13:05:55] [VERBOSE] Operation 'Invoke CimMethod' complete.
[01/16/2024 13:05:55] [VERBOSE] Set-DscLocalConfigurationManager finished in 0.142 seconds.
Operation on resource 'appGatewayNestedDeployment-azuredeploy-0116-1859' succeeded
Deployment Error:- The deployment encountered the following errors
The resource WebGIS-Pri/DSCConfiguration of type Microsoft.Compute/virtualMachines/extensions failed.
Error:- The resource write operation failed to complete successfully, because it reached terminal provisioning state 'Failed'.
<b>VMExtensionProvisioningError</b> - VM has reported a failure when processing extension 'DSCConfiguration' (publisher 'Microsoft.Powershell' and type 'DSC'). Error message: "DSC Configuration 'BaseDeploymentSingleTierConfiguration' completed with error(s). Following are the first few: PowerShell DSC resource ArcGIS_Federation failed to execute Set-TargetResource functionality with error message: [ERROR]:- Federation Failed after multiple attempts. Error:- @{code=400; message=Invalid administrator username or password specified. Verify the username and password are correct and try again.; details=System.Object[]} The SendConfigurationApply function did not succeed.". More information on troubleshooting is available at https://aka.ms/VMExtensionDSCWindowsTroubleshoot.
