ArcGIS Enterprise Log4j Vulnerability (CVE-2021-44228) Patch or Mitigation?
47975
162
12-11-2021 09:13 AM
Carl_Flint
New Contributor III
Good afternoon, is there any patches in the works or potential mitigation steps for the latest java log4j vulnerability (CVE-2021-44228)?  I know that GeoEvent server uses log4j and can assume some other enterprise server's or portal potentially do as well.  Any help would be appreciated in resolving this zero-day.
Carl Flint, GISP
RandallWilliams
Our current statement is available on https://trust.arcgis.com. Look for more updates as this issue evolves.
IngaPlayle1
I'm also waiting to hear any news from ESRI about this.
JoshuaBixby
MVP Esteemed Contributor
A quick filesystem search on a stand-alone ArcGIS Server installation shows numerous components using log4j.  This won't just be about patching a file, but lots of files involving multiple components of multiple products.  A not-so-happy holidays for Esri dev teams.
AndresEcheverri
Really interested on this topic too.
JohnBrockwell
Occasional Contributor III
I found it here on my Portal for ArcGIS server:
E:\arcgisportal\upgrade-backup\10.5.1\dsdata\elasticsearch_2.3.2\lib
File Name:
apache-log4j-extras-1.2.17.jar
The file is located in a 10.5.1 backup folder. I am currently running 10.8.1. Does it matter?
RandallWilliams
Sorry for the delayed reply. I see what you're saying, we made a backup when you upgraded. That's a backup in case your upgrade failed and you needed to bail out. I'd maybe archive it on an offline drive and just delete that directory.
ALLANGILLIS
That version of Log4J is not affected.  Only versions 2.0 - 2.14.1
https://www.zdnet.com/article/log4j-zero-day-flaw-what-you-need-to-know-and-how-to-protect-yourself/
OmerBen-Asher
New Contributor III
also interested
Scott_Tansley
MVP Regular Contributor
Following.  Thanks for raising.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
MarkusRuottinen
Also following.
