Hi Folks,
I use arcgis Pro 2.8.6 and arcgis Server 11.1.0 version to publish the map service. This service is issued through Arcgis Pro and I have defined layer labels expression using labelling. Labelling also contains layer class where I have configured the properties of labels like font, colour, position and appearance.
I also use the stacking option to stack the label's text if they are longer than the defined length. When I check this layer in arcgis online / map viewer it looks fine with the correct label position and stacked label text.
But when the same layer has been rendered into our application base map, it does not display correctly and the position labels get changed, also the stack properties do not work. Label text stacked works randomly it is stacked for a few labels and others not.
Also, labels are getting repeated when I zoom in.
Is that a bug? Or Am I missing something here? Please help me identify the root cause of this problem.
FYI: I have added the screenshot for arcgis Prod, Arcgis online and our application.
Arcgis Pro:
Arcgis Pro
Application Render Screenshot:
Application Render
Arcgis Server Manager Service details Screenshot:
Arcgis Server Manager service details
Arcgis Online Screenshot:
Arcgis Online
