ArcGIS Server 10.2 Authorization error: prvs is an invalid file for a single use authorization
6339
08-30-2014 09:42 AM
Frankwang
I encountered this error message on August 29, 2014:
Here are the steps I used to create provision file:
Log in my.esri.com
Go to Products >> Authorizations
Select ArcGIS for Server Advanced Enterprise  version10.1 - 10.2.2
click on Authorization code
After provision file is created. I download it to the server where ArcGIS server.
Then,
  1. Launch the Software Authorization Wizard from the ArcGIS for Server;
  2. Select the option "I have received an authorization file from Esri and am now ready to finish the authorization process."
  3. Browse to the provisioning file you saved.
It is the place where I received the error message:
"prvs is an invalid file for a single use authorization"
Frankwang
ESRI confirm this is a bug in my.esri.com.
The solution is to rename the .prvs to .prvc.
thank you.
RuwaidahSubhi
Try to make the extension .rsps
Frankwang
thank you.
