I have noticed that the returnUnformattedValues and returnFieldName parameters of the REST API is not working for the Identify on MapServer. Is there something special to enable to make it works? The doc says that it was added in 10.5
I took a screenshot of a request made to the REST endpoint. I have put a red rectangle around an attribute that is part of a domain and the coded value is not returned as expected. Also, the alias of the fields are not returned as expected with returnFieldName parameter set to false;
