ArcGIS Server "image server" error
1712
05-30-2018 02:39 PM
RoyceSimpson
I'm getting a severe error in ArcGIS Server that has something to do with image server but I can't figure out what it is or how to stop these errors.  I don't have any image server services running so why these errors are happening.  Any advice on how to get these to stop would be great. Thanks.
SEVERE    May 30, 2018, 2:54:02 PM    Error handling request to service 'System/RasterProcessing.ImageServer'. The service 'System/RasterProcessing.ImageServer' was not found. Verify the service exists and is started.    Soap
SEVERE    May 30, 2018, 2:54:02 PM    java.lang.Exception: The service 'System/RasterProcessing.ImageServer' was not found. Verify the service exists and is started. at com.esri.arcgis.discovery.wsh.util.WSRequestUtil.getService(WSRequestUtil.java:328) at com.esri.arcgis.discovery.wsh.ServiceHandlerServlet.service(ServiceHandlerServlet.java:151) at javax.servlet.http.HttpServlet.service(HttpServlet.java:731) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:748) at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:486) at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:378) at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:338) at com.esri.arcgis.discovery.wsh.DispatcherServlet.service(DispatcherServlet.java:181) at javax.servlet.http.HttpServlet.service(HttpServlet.java:731) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) at
x (x)
RandallWilliams
RasterProcessing.imageserver is a system tool and exists on all newer ArcGIS Server installations, so it does exist - it's not started by default though. I'm not sure why you're getting an error like that - but even when I start and attempt to access either the SOAP or REST endpoint for this service I get either an http 500 or 400, respectively. May be because I don't have my GIS Server configured in the ImageServer role. The error reads like something made a request to this service and couldn't find it. Which version are you working with?
RoyceSimpson
Hi Randall.  Everything you say makes sense.  The problem is, when I go into Manager, then "system" and look for any kind of raster or image service... I don't see anything.  Should there be something there by default, out of the box?
I'm runing 10.4.1.
-r
x (x)
RandallWilliams
It's not there in the 10.4.1 server I have access to either. I've seen weird logs when an invalid service name is accessed, but I don't see anything in the log you're looking at. Are you doing any administration in ArcMap? I ask because ArcMap makes SOAP calls to ArcGIS Server and these days would be the most common client to make a SOAP request.
That said, I tested with ArcMap 10.6 against my 10.4.1 server, and don't see any errors like that. With that said, it looks like some client somewhere is trying to make a request to a system service that doesn't exist on this resource. Portal only makes restful calls...
Might be able to take a look at the web tier logs and correlate the time stamps and find the IP of the client that's reaching out to your server(?)
RoyceSimpson
That all makes sound sense.  Will have peek at those web logs and see if anything pops out.
x (x)
