CachingToolsEx randomly crashing
1356
12-18-2019 09:09 AM
spiskulaspiskula
New Contributor III
Hello,
Since a while when running tile caching of a Map Service published from ArcPRO 2.4 on Standalone ArcGIS Server 10.7.1 on Windows 2016 (Azure VM size F64) i get randomly, after different periods of time, following crashes in ArcGIS Server Logs:
SEVERE18 Dec 2019 15:15:03Service containing process crashed for 'System/CachingToolsEx.GPServer'. Please see if an error report was generated in 'C:\arcgisserver\logs\<machine_name_here>\errorreports'. To send an error report to Esri, compose an e-mail to ArcGISErrorReport@esri.com and attach the error report file.Server
No reports generated in ‘C:\arcgisserver\logs\<machine_name_here>\errorreports’
I found in n Windows  Logs>Application:
Faulting application name: ArcSOC.exe, version: 12.4.0.19608, time stamp: 0x5ce60b9f
Faulting module name: ucrtbase.dll, version: 10.0.14393.2999, time stamp: 0x5ce36be6
Exception code: 0xc0000409
Fault offset: 0x000000000006e00e
Faulting process id: 0x8428
Faulting application start time: 0x01d5b5b5ea7edd76
Faulting application path: C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin\ArcSOC.exe
Faulting module path: C:\windows\System32\ucrtbase.dll
Report Id: f3697555-71cc-413a-af0f-cefe7c06c911
Faulting package full name:
Faulting package-relative application ID:
It happens that caching would run fine for 4-5 days, it happens it crashes after 8hours. I cannot see a pattern so far.
Any thoughts please?
Regards,
Szymon
SurajPai1
Just wondering if you managed to resolve the above issue? I'm also seeing similar issue at version 10.7.1
spiskulaspiskula
New Contributor III
Hi Suraj,
I dont have a solution yet. Can you please collect as many details of your issue and place them here? What sort of machine are you using/virtual in cloud or phycical?
What exact operating system?
What version of ArcPRO?
Please provide as many details about your data as possible - local FGDB or referened from SDE?
What antivirus?
Under what account do you run ArcGIS Server - local or domain?
Does the issue happen always for the same area that you cache or is it random?
Do you ever get your cache build successfully?
Do you have a pattern that would allow reliably reproducing the issue?
Please, the more details you provide the easier it will be to help Esri looking for a fix.
Sigurd_TofteHaagensen
Did you find a solution to this problem?
We are experiencing a similar error situation with ArcGIS Server 10.7.1
Our error situation is not related to cachingToolEx.gp, but regular map services 'folder/map_service_name.MapServer' crashed.
