Can ArcMap 10.2 clients publish to ArcGIS Server 10.3
3385
01-26-2015 06:16 AM
ThomasColson
MVP Frequent Contributor
Can ArcMap 10.2 clients publish to ArcGIS Server 10.3? Thinking of pulling the trigger on upgrading my site to 10.3, but in no way am able to update 60+ desktop installs to 10.3 as well. What will we NOT be able to do with desktop 10.2 hitting server 10.3? Usually ESRI posts a compatibility matrix....not to be found. Can a 10.2 desktop publish a service to 10.3 server? Can 10.2 desktop perform disconnected feature service edits from a 10.3 server?
KyleDixon
Yes. I'm doing it regularly. If you're saving an sd file, be sure to connect to the 10.3 server.
KyleDixon
JoshuaBixby
Unfortunately with Esri, I have reached a point of seeing is believing, regardless of what the documentation or staffers say.  That said, your question is addressed in more detail in the online documentation:  Compatibility of ArcGIS 10.3 for Server with earlier versions.
