Can I create a custom layout template with adjustable dimensions?
840
04-28-2021 09:10 AM
by Anonymous User
Not applicable
Hello Community,
I have a series of web maps in enterprise that I would like to be able to print, and I have made a custom layout template in ArcGIS Pro for them and created a print service to publish to enterprise (following the instructions I have found here). The problem I am running into is that I will need to print the maps in various different dimensions. I was wondering is there a way to create a single template in which I could adjust the dimension when I go to print? I would like to avoid making a template for each dimension.
Let me know if you have any advice or maybe you could point me in the right direction? Also, please drop a comment if there are more details that I can provide that would help.
Thank you,
Jacob Long
GIS Intern - IF Power
TanuHoque
Hi Jacob,
Unfortunately that is not supported via a print service. You need to have your templates of different size authored and shared with your print service.
by Anonymous User
Not applicable
Thanks for the reply Tanu, I'll just make a template for the different dimensions I need then.
