I just set up a new AWS instance, set up an SSH connection, and changed the postgresql passwords for sde, owner, postgres. I want to create a new GDB using the Create Enterprise Database tool in Catalog 10.2.1. I try to and it just hangs for hours at a step seen in the interface below.
The GDB is created but it is not spatially set up and therefore will not accept rasters or do anything fancier than tables and basic Feature Classes.
Any suggestions? I'm a bit frustrated by how much the documentation varies from reality when I log in and navigate the interface. Ie. drive mounts are different names now, directories vary, etc.
