Raj,
It still doesn't work properly...I've done all those checks you enumerated several times and I still get the following error dialog:
[ATTACH=CONFIG]18081[/ATTACH]
I've tried granting "PUBLISH" and "ADMINISTER" privileges to the AD Role that has the username used to make the connection when adding the ArcGIS Server. I verified the privileges using "http://localhost:6080/arcgis/admin/security/users/getPrivilege" for both instances of "PUBLISHER" & "ADMINISTER". - Still, no luck...
It's not a show-stopper, but a real pain in the rear...creating a .sd, importing into ArcGIS Server, blah, blah...
Publishing works great if the Web Adaptor/Windows authentication isn't involved...
Please let me know if you have any other suggestions, because at this point my organization is ready to call it a bug...
Regards,
Troy
To publish from Desktop using Integrated Windows Authentication, please check if:
- ArcGIS Server security has been configured to use Windows users\roles and Web Tier authentication.
- The ArcGIS Web Adaptor has been configured to allow administrative access to the site.
- IIS has "Anonymous" authentication disabled and "Windows" authentication enabled.
- In the ArcGIS Desktop "Add ArcGIS Server" wizard:
- The "Server URL" parameter has http://iishostname/arcgis and not http://arcgishost:6080/arcgis.
- The "Authentication" section has the credentials of a Windows user(not the Primary Site Administrator) who is a member of a role with Publisher\Administrator privileges. Please use http://arcgishost:6080/arcgis/admin/security/users/getPrivilege to confirm the user's privilege
If you need instructions on configuring ArcGIS Server for Integrated Windows Authentication, please see the tutorial Securing web services with Integrated Windows Authentication
Regards,
Raj
